Batt light on and system ain't charging the batts.
Deereman4020
Out in the fields in Wisconsin
I'm having issues with the batt light being on continuosuly, I had the batts and alternator fail on me within a week so I replaced both, along with the fender mounted solenoid. I'm out of ideas and need this truck running again by the weekend.
swamp_ratt
hudson, wi
Check yer connections at the alternator and the wires from there to the batteries. Get a volt meter and test the alternators output. Possible you got a bad alternator
swamp_ratt
hudson, wi
Yeah jus hook the volt meter to yer posts on yer battery when your truck is runnin. Should see about 14 or so volts
tankmech_250
Jacksonville, nc
I don't have an obs so I don't know how differant the systems are but I had the same problem. Disconnected the gpr and relay on passenger fender hooked it back up and its fine now. I think I originally had the cable to the gpr on the wrong post on the fender relay.
Tom S
The battery light is fussy with that one wire connector on the top of the alternator.
