Battery light p0620 code on 6.7
Cutting-Edge Diesel
Newkirk, OK
Yeah it's a warrenty item but we have to use the truck every day to haul the 4 wheelers to the trail head. And its missing it's dpf and egr. Lol it seemed to get better so we are going to drive it home at the end of the week and just let our dealer work on it.
Wasn't really planning on going to durango.
carcare
If you haven't figured this out yet I had Dodge 2500 charging 17 V the other day and it was caused by resistance built-up by bad connections at battery
carcare
Cleaned connections on both batteries and had 14 idling when done . They also have batterie temp sensors that report to the PCM
ogden utah
I have a 2013 with dual alternators on it. Took it in and had the alternators tested and they said the upper one was low replaced it and the light is still on. It has 13.5 volts and is charging truck just stays on also has a p0620 code what am I missing any help would be great.
