Beans71086
Ok truck is running pretty good except a couple glitches.
- fuel temp sensor
So when we did the DIY fuel system we didn't add a fuel bowl delete block. So the sensor in the fuel bowl is unplugged. My question is, will this effect/hurt anything? Does the tuning of the engine depend on the sensor at all?
- regulated return
We didn't install a regulated return, my theory was that the check valve we left in the return system would act as a regulator of sorts because it takes X amount of psi to open the check valve. But in the higher tunes I'm getting a fluttering in the throttle under light acceleration. The rail pressure doesn't flutter though.
- fuel temp sensor
- regulated return
