Fastlane17
Hello! Name is Lane, AirForce stationed in Florida and im new to the Power stroke, Ford life. Just got rid of my 24v cummins, and i've wanted a 6.4 for awhile. Found a good deal on one, will be picking it up next week.
but i have a transmission question...
part of build list: light motor build, studs, fuel system, s371, gear head tune, 3.73, 305/50/20 nitto 420s.
at WOT in 20-30 the trans almost slips, hunts for a gear, then starts to pull... 40+ and dead stop launches are fine.. any ideas? been reading al ot about solenoid swaps.. curious if that would be a temp cure?
also truck is around 650ish.. stock trans.. what should i start looking into for trans mods/ build specs? just a converter, clutches, output shaft? not looking for anything crazy... 800rwhp ish.. also located 10 minutes from suncoast but have heard mixed opinions.
Thank You!
Thank You!
