Bellow up pipes
PSDEng
Bellefonte, PA
I'm running one of his T4i kits with bellowed up pipes. I've seen his other up pipes in person, and I haven't heard of anyone who has had fitment problems with them.
PSDEng
Bellefonte, PA
I'm not sure, I've had my kit for awhile so they may have changed. Best bet is to give him a call and ask.
Bad-Medicine
I installed the Irate ones yesterday before they went up to $600, required taking transmission down which I have. Mine didn't fit right in had to wiggle the engine little with a jack to fit between the firewall and engine. Look well build but would suggest throwing the (2) 8.8 metric bolts that bolt to turbo and get some 10.9 metric ones to match the two studs that came in stock and also buy a 17mm swivel socket the 15mm won't work anymore.
zilla68
Moore Oklahoma
you had to drop the tranny just to install the pipes?
is this something that you have to do on all pipes like this or just this is an isolated case??
gnxtc2
Bergen County, NJ USA
When I installed the Irate pipes, I did not have to do anything. I believe it depends on the condition of the truck's motor mount and body bushings. Also it depends if you have a stick or auto. I have an auto.
Billy T.
[email protected]
