Best Injector Builder?
HobbyStock62
Mpls, MN
I got a set of injectors and want to get them flowed to see i they are any good. One injector tip is broke off and chewed up the piston, so I dont know what can be done there, but basically want to know if they are any good and if i can build those to somewhere around a 225/75. im leaning towards rcd, but really havent looked into other companies/prices. any thoughts?
thuglike
Linden, NJ
We sell Holders Injectors and a set built from your cores will be ...(PM ME)
All injectors get fitted with a new nozzle, new internal and external O rings, new upper springs, new lower springs, and everything reassembled and torqued to the proper specifications.
After all injectors are reassembled, they are then tested on Holders in-house flow bench and packaged with a flow sheet indicating the injector test results.
Injectors built from customer cores carry a 6 month warranty.
