I'm trying to figure out if my brother should/can upgrade his brake. As the truck sits now it take about a half a Honda to stop and there's a very good possibility that the brakes are worn slap out. So what I'm looking for is some one that's running the same set up, or something very similar to this, that can tell me if replacing all the wear parts with brand new parts will solve the problem or is he just going to have to upgrade to a better set up. If he going to have to upgrade than whats the best route?
I don't think anyone can answer if replacing what is warn will fix the issue...
enough..without doing in person diagnostics...
but a good set of F rotors, with some EBC yellow stuff pads....and then rebuild/replace the rear drums as necessary would be a good starting point...
I've heard of (some) OBS guys converting the rear drums to rotors (something about Cadillac bracketry?)...so do some googling/searching on rear (caddy?) rotors for OBS trucks...if you want...but upgrading the fronts with quality chit, gravity bleed the lines, & add new fluid, would be time & money well spent.
