So I may be in a bit of a pickle, but am not quite sure...
In the middle of final assembly of my motor. Got a set of heads from a vendor here to use on my 03 build. Was beginning installation of the billet plenums from Riff Raff and noticed a peculiar difference. All but two holes line up on the plenum to head. Compared it to my old heads and spotted the difference. The rebuilt heads only have 8 bolts on the intake and my old heads have 10.
For comparison..
New:
Old:
Did some research and found that the heads are supposed to be identical, less the number of bolt holes. Are there any advantages/disadvantages to the different designs? Why did Ford change to the 10 bolt design? Boost leaks?
Already thought about exchanging the plenums but read that they're not for 8-bolt intakes - and they're back ordered. But 8-bolt is what I have now! Really want to finish up this build.
So this is what I am thinking...Being these plenums are rather thick where the bolts are, I am debating on tapping the two holes and sealing them up with a flush-mount bolt and a dab of some Ford RTV on the rear where the o-ring slightly misses.
Thoughts?
For comparison..
New:
Old:
Thoughts?
