Billet torque converter E4od 4R100
kip4234
7U2Z7V902A E4od 4R100 6 stud torque converter Genuine Billet all new nothing used in it. Missing one stud. Not broke off just missing. I am sure someone could source or machine one as it screws into the converter 400.00 shipped continental USA or would sell for 340.00 if picked up local
kip4234
I still have this converter Brand new not rebuilt these are really good converters. New Ford never reman Billet I need this gone open to offers very heavy would make a better deal if someone could pick up Dallas Plano area let me know.
kip4234
Here's the part number to Ford's HD Torque Converter: 7U2Z-7V902-A
Here's the magic ingredients list:
•Billet cover, with 85% less deflection than standard cover
•Triple disc / plate clutch / damper assembly
•Turbine assembly thicker
•Turbine assembly made of 1020 steel
•Turbine assembly furnace brazed blades and blade retainer
•Forged heat treated turbine hub
•Heat treated splines in the turbine hub
•Stator assembly upgraded with offset one way clutch
•Stator has preloaded thrust washers to improve durability
•95K Impeller assembly with 1020 steel brazed blades
•Torrington bearing
kip4234
I don't know the answer on Horsepower I am running one with over 500 horsepower. They are 100% brand new.
kip4234
7U2Z7V902A (TCV70)
Desc: CONVERTER ASY
Cost: $838.59
Max Disc: N/A
List was $1100.00
