suprdzlduty
hey guys, got a 06 with a II 62/70. when the truck came in it needed some injector work and a new intake. had a k&n on it and would suck the filter minder in on it if you got into the throttle at all. did the injector work and put a afe stage 2 intake on...now the truck has a squeal at exactly 21lbs of boost...at first it almost sounds like something electronic is beeping but it increases and pitch changes as boost level increases. it has new up-pipes.will the wastegate squeal on these turbos? I assume the noise or problem has always been there but the k&n was choking it down enough to hide the noise...any ideas? new intercooler boots and a mishimoto intercooler as well.
