Borg Warner S366 Special!! $575 ONLY TILL SUNDAY NIGHT!
SmedingDiesel
S300SX3-66 .91 A/R (Straight Compressor Outlet)
BorgWarner Airwerks S300SX3-66, S366, S300 91/79 with .91 A/R Twin Scroll Turbine Housing.
Rated at 500 to 830 HP
Compressor flow is rated at over 82lb/min
Wheel Dimensions:
  • Compressor: 66 mm inducer / 91.4mm exducer, with exclusive Extended Tip Technology.
  • Turbine: 80 mm inducer / 73 mm exducer. Cast in Inconel 713 for high-temperature operation
Housings:
  • Compressor: Large 4.00" ported anti-surge air inlet / 3.00" charge pipe outlet
  • Turbine: .91 A/R Twin Scroll, with 'T4-style', divided entry, and 4.21" v-band discharge.
VISIT THIS LINK TO ORDER
http://www.smedingdiesel.com/ProductDetails.asp?ProductCode=PA177275
:gun:
