Beans71086
Going to install my bov this weekend, it says on BDs site to put it on the cold side. But I know I've seen guys with it on the hot side pipe, so which is better?
they say hot side closer to turbos is better. but cold side works too.
Subscribing out of curiosity. I thought it's rare to see a BOV on a diesel?
Id prefer the cold side. Although it is farther away, youd think it would be better for whatever seals and components that are in the bov to have cooler air going through it
The whole idea of a bov is to eliminate compressor surge, so closest to the compressor for the fastest relief of pressure in that area is always best.
Back when I had my turboed integra everyone suggested to keep the bov as close to the throttle body as possible to eliminate the lag between shifts. The theory was you would only be loosing the small amount between the valve and throttle body instead of draining the intercooler and such resulting in increased lag. Whether this was true and made a difference idk.
While I understand this thought, wouldn't the build up of pressure start at the engine? I dunno how quickly valves react, but wouldn't releiving before it got to the turbos be better?
I dunno much about the import world, but I'm told there used a lot there. As far as the 6.4 diesel world, the bigger "stock appearing" turbos (71 72 76) don't like to be barked. I have a 72 on the way and I'm hoping for it to have a long, import smashing, life. Lol
Didn't really give that a thought, another plus for the cold side for sure.
What do you mean before turbos?
So is barking when you let out of the throttle fast and it sorta goes whomp whomp whomp? I've got that BAD.
really interested on what you do beans this would reallly benefit people that have bigger turbo wheels in their stock housing to keep them lasting longer Im not saying the turbos wont last long but this will help them greatly. Thanks for the thread in for results when you get everything figured out
U stock turbo guys are funny lol. Have a big single spooled to about 20psi at 50% throttle and the converter locks. Thats a turbo bark!!!
Im going the workstock route travis even though single turbo 6.4 sounds amazing
Where are you from bud?
