JohnT24
1995 F350 7.3
Bought the truck new/ 150k miles.
I currently have the engine out to replace the exhaust manifolds and the oil pan.
I am fixing the body mount support on the driver side
But besides that I’m just cleaning things up and putting it back together
But
I want to go with bigger injectors
I have already purchased a 1.0 housing
Because my stock 1.15 housing had some broken bolts and also I want the truck to spool up a little quicker because that’s the RPM range I drive in.
So here’s my question
I am looking at injectors
But the high-pressure oil pump is the issue
I haven’t tested it and I don’t know what it’s putting out but I’ve baby this truck it’s whole life.
I would love to go to stage 2 injectors
So if I have to change my HPOP
What should I go with?
I’d rather spend the money now
I’ve heard bad things about the adrenaline HPOP
Is there any other alternative?
To sum things up …
I want to go with the biggest injectors I can get without replacing valve springs and head studs.
If I have to replace the Hpop
I just need to know what to go with
What are my choices?
Thank you
But
To sum things up …
Thank you
