building own compound kit
jrex2506
ok I plan on building my own compound kit using a 475. I have a couple questions. what is the best diameter and thickness stainless steel to use for the piping? i just don't want my pipe to be too thin. also for people mounting on the passenger side does it need to be supported other than the hot and cold pipes? Also where is everyone ordering their pipe and other parts from?
gwunter
Logansport, IN
Forgot to say that I run schedule 10 for my hot piping. Could use scd40, but probably overkill.
Sent from my SAMSUNG-SM-G800A using Tapatalk
your turbo should be mounted in such a manner that there is no weight at all on either the hot or cold pipes.
jrex2506
Ok thanks for the help. What diameter pipe yal using?
Sent from my.....i forgot.
