HOOV3R
Are you positive the solenoid wasn't damaged on the injector when torquing? I've saw that done when someone tries to use a standard length torx bit and accidentally puts pressure on the solenoids.
Some people overthink things sometimes it seems, to much milled off the heads and shorter push rods needed....be realistic LOL
Buzz test/power balance, check make sure rocker arm didn't crack or isn't broken, if not swap injector and call it a day. Pulling valve covers isn't that big of a deal obviously.
But if it left with a miss why did it leave at all in the first place...... Or did I miss something and it develope this later on.... Sometimes pulling injectors etc and putting them back in odd things could happen, if they weren't put directly into a injector trey could of gotten a little debri etc who knows.
My best guess here is mistorqued injector, ie hold down in incorrect spot when torquing, then it turned while running, and you have an issue now. Ive had this happen several times, usually happens on 5 & 7 when doing them as theyre kind of a pita to see when youre putting them in.
Yea, it'll come off this afternoon. I should be there when it does to see what's going on.
What about a cracked injector nozzle? I changed one on another 03 last year that was acting similar to this...was throwing the same type of contribution code too.
Got a badass over here.Well would u just look at that... Hey airfish diesel Jesus ... Is it too early for I told u so? Or should I wait. Doesn't hurt to hear out what others have seen/ experienced.
