Call it my build thread I guess
TXlineman83
Austin, TX
So I've been buying parts slowly. Putting things together. So here's my list. Few things are changing. Pics are soon to come.
Arp head studs
Flo-pro intake elbow
6.0 exhaust manis
Elite Stainless HD up-pipes
Midwest Diesel stage 2 intake
Rudys Diesel stage 1 valve train, pushrods and springs
Elite Diesel JR High power compounds
Mishimoto Radiator
Fass Fuel LPFP
SCT livewire with Gearhead tunes
Afe stage 2 intake soon to be No limit
As assembly comes along so will the pics. Hoping everything works smoothly together.
Going to have to get a trans soon with all this
"Opportunity is often overlooked because it is dressed in overalls and looks like work"
Thomas Edison.
TXlineman83
Austin, TX
Next week most all my parts will be in and I can post more.
Thomas Edison.
TXlineman83
Austin, TX
No. I was going to do the work and use one of our boom tip cranes at work to pull my cab off. However I found a shop that seems pretty level headed and worked out a great deal. It works out for both of is
They are having my heads cleaned up, valve job, bronze guides installed for my pushrods
Thomas Edison.
TXlineman83
Austin, TX
Thank you. I must say it was a result of some great people I've met on here. Much appreciation to the help, guidance and parts I've acquired. Seems there are still some honest people out there. Thanks Riverside
Thomas Edison.
TXlineman83
Austin, TX
Well no limit just turned into a Afe Eltie stage now instead. I think I like the shield that's offered by the afe. Not for the heat shield but for the protection
Thomas Edison.
TXlineman83
Austin, TX
Yes. Stock high pressure and stock injectors
Thomas Edison.
TXlineman83
Austin, TX
Plans r to get it together. Break it in slowing and make sure no issues arrive. Then dyno, data log and tweak if needed.
Thomas Edison.
INFAMOUS
Denver Colorado
Why aFe over No Limit? That is going backwards in my book. I believe that will also void the warranty on your turbos. The No Limit intake the is the only one that will flow enough air for them.
Sent from my SCH-I605 using Tapatalk
HOOV3R
Central PA
Says soon to be No Limit.
TXlineman83
Austin, TX
Actually it's the elite upgrade afe intake that I purchased. I know everyone swears by the no limit. But I like the shield that I get to keep protecting my filter from water splash. I may have to go to a no limit eventually. But the Elite upgrade is better then stock afe stage 2 I had.
Thomas Edison.
bigrpowr
<How I Fly
Administrator
Thomas Edison.
Thomas Edison.
the no limit includes a free pre filter for water and heavy dirt issues. anyway good luck.
