That track rod looks interesting. It looks like it is rubbing on the front axle and doesn't look like it even has the clearance for normal driving around. It is almost like it is installed incorrectly or made incorrectly. I wouldn't drive around with that like that.
Are those grade 5 bolts holding the steering linkage on? Kind of look like it from the picture.
It also looks like the mounting plates for the track rod are squeezed together pinching the track rod. How is it supposed to move when it is pinched like that?
Also looks like the drag link is rubbing on the track rod bolt or the lower bracket.
The least they could do from the getgo is give you the proper length bolts for everything.
I would probably go back to your old setup. If you can send that stuff back I would. Or at least send them a picture of your truck and make them fix it.
You will not be able to get your truck fixed running a setup like that.
