Can anyone tell me how to remove the arm rest from my front seats?? Im doing the console delete to put in the jump seat and need those damn things out of the way.
you need to pull the arm rest cover off, reach behind the arm rest where it joins the seat and you should feel where the opening is, it takes some work but you should be able to stretch the cover and pull it off the arm rest enough, once you do that there is a torques bolt that holds it in place...hope that helps ya
I never found one for the right year model worth the money, ended up buying an older one with the big lid, no cup holders. Got it for 125 bucks at a factory take off place. He had had it for years on the shelf and was glad to see it go. Fit just fine. Cloth is just different but still tan.
