Captian Murica Build
6 L chevy eater
Franklin, VA
Mines doin the same chit, I can get one good foot brake out of it a day.When convertor gets hot mine won't do chit on the foot brake. Zero boost and when u let off the brake it still don't wana hardly move
RedRice589
Ocala, Florida
So... odd issue. Was spooling up the truck to run a vette the other day and it fell on its face mid spool. After 2k rpms it lit and hit full rp. Anything under 2k and it is sluggish as hell. Can't brake spool anymore and no codes
Once it gets moving it has full power
Got scared.... It's trying to tell you something...
blk350on20s
Sounds like your convertor got super loose. Won't load the chargers so it won't fuel. Once it gets going and sees some boost it fuels. That was my problem with to high of a stall. When I had the 2200 in it worked great.
blk350on20s
Yep. I did that multiple times with my precision. The DPC ones seemed to be fine until this last one. Couldn't brake spool for ****. The other ones would but they would eventually blow threw the lockup clutch.
