Captian Murica Build
BOSS450
Concord, NC
I'll agree that the shafts are the same strength. But with the correct transmission builder and proper pcs tuning those shafts last a lot longer. Clutches also last a lot longer then a 5r will. I'm not trying derail this thread or take anything away from MPD or KK. If you wanna have this discussion I'll do it in another thread don't wanna ruffle any feathers here
Mike@MPD
Pasadena,MD
It's all good. What has worked best for us on our truck has been the 48. 4r 100 is still one hell of a trans and I am not taking anything away from it
Sent from my SM-N920V using Tapatalk
BOSS450
Concord, NC
Yeah I'm stubborn. All the guys around me drive dodges. Only thing I have against a 47 or 48 is the drivers. Excited to see where this goes!
swinky
Eastern, Nc
The only thing you gain by switching from a 5r to a 4r is quicker shifts, the 4r swaps work well in lighter trucks.. Shafts aren't any stronger than the 5r.
5r's have gotten so good that the 4r swap isn't want it once was.
48 is king
Clutches live longer with quicker shifts.
Six_Sloww
Southeast MI
Like i said, I over-simplified it.. Quicker shifts are good for a number of reasons, also no chance of tying up the swap shift.
Radioflyer
How much stronger are the shafts in a 48?
Most of your high hp Duramax and Cummins trucks have 48's behind them. I've seen trucks running 1600hp+ and don't have a shaft issue. It just becomes a converter game at that point it seems.
Cool to see one going behind a 6.4 Mike!
jimdawg185
I'm torn between the 48 and 4R. Do I need a pcs with the full manual valve body Mike. Can MPD get me everything to go with a fire punk 48 manual vb?
BOSS450
Concord, NC
Yeah I'm sure the can.
Just depends if you want to shift it every time you go down the track
jimdawg185
I hear ya. I actually like shifting manually. But would rather stay with a Ford trans if it will hold well enough.
Jomax
Arizona
48 is king
What makes the 48 so much better then a 4r100?
jimdawg185
It's really the oversized shafts that make it what it is, right? That and manual valve body option....
Mike@MPD
Pasadena,MD
So a little update. Finally got the motor apart to see what I hurt on it. Needless to say it was a bad day
