KingStroker
Well, as most of you know I have been blasting forums with questions about Carli suspension systems..
I finally decided on Carli tuned 2.5 Pintops with front coils, and complete rear Carli/Deaver leaves. I will retain the weak rcx drops for the track bar and radius arm drops for now, being they are 4.5" also. Brake lines, bump stops, the adjustable track bar, and most likely a 4-link will be done eventually.
I have heard about people having trouble with the rear spring removal, and a couple clearance issues with the huge 2.5" shocks.
What is the best way to get the driver's side spring off (without dropping the fuel tank)?
Will my 5" exhaust get in the way of the shock, if not, how close should be allowed for heat reasons?
Thanks in advance for all input you may have!
-Zack Wilson
-Zack Wilson
