Carli and One Up Offroad Items
Swampfox
TN
I have returned my truck to stock and have some carli and one up offroad stuff for sale. Everything has around 7k miles on it and is in good shape. Few scuffs here and there as this stuff is used. Prices are listed below and shipping can be discussed. Will be a better deal if picked up in person but can put everything on a pallet also. All hardware is included. The add-a-packs will need new center pins and the traction bars I would recommend the new hardware kit ($53). The carli is not a complete kit but is the majority of it, reason for listing the parts as what I have. Located close to Memphis, TN.
One Up Offroad
Axle truss and fox 2.0 shocks steering stabilizers - $500
Adjustable link arms - $1000
3.625” (f-350 factory size)traction blocks, mounts, u-bolts, top plates, and bars - $900
Carli Suspension
4.5” Coil Springs - $275
Track bar - $275
Sway bar and bump stop drops - $100
Add-a-packs and u-bolts - $600
4.5” Fox 2.0 shocks - $900
Swampfox
TN
Rest of the pictures attached.
CrashedCT
Woodbury,CT
I’m definitely interested in the 4.5” coils and front shocks.. let me know price shipped to 06798.. PayPal waiting.
Mhatlen
Dorrington & Elk Grove California
I'm interested in the adjustable link arms. Let me know how much shipped to 79602.
I sure wished I bought those instead of the Fabtech radius arms. You will love how those look and how truck drives with them if you have stock arms with drop brackets.
I was extremely pleased with how well my Fabtech arms made my truck drive. Truck tracks so much better too when you are straight to the radius arm mounts. Eliminates hunting around on the road even with 7” of suspension lift. Drives straight as string and those 3 link arms look like OEM . Better then my big radius arms.
I hope you get them, you have fabulous caster adjustment with those too.
8WR_ZJ
Is tractions bars for a LWB truck?
Sent from my SM-G965U using Tapatalk
C2tuck
North Texas
Yeah I’m interested in the traction bars as well if they work on SWB.
They're OUO!!! They work on any cab/bed/lift configuration because they're adjustable.
C2tuck
North Texas
Will the 350 blocks work on a 250 with camper package? If not can they be swapped out for the correct blocks?
jbaum02
Abilene, TX
I’m running a Carli Pintop leveling system so no radius arm drop brackets.
I’ve been interested in the OUO or PMF arms for awhile for the ability to move the axle forward a hair to alleviate the bow in the coil springs and for the increased caster adjustment over the balljoint sleeves.
Swampfox
TN
For some reason I didn't get any notifications on this thread. I will go through and get back to each and everyone of you ASAP. Thanks
Swampfox
TN
Adjustable
That is correct. They were on a shortbed truck and have been drilled. Worst case you can get the replacement front bar from OUO for $125 I think.
I had them on my swb with a 4.5" lift. What does the camper package consist of? They are basically like the factory block just a lot stronger with the trac bar mounts and are adjustable to center the axle in the wheel well. I might have some pics I can send or put on here to show how they look installed.
Mhatlen
I am sure the blocks will work fine. I’m almost positive the Sterling axles still used today in the 2018.
Quite universal.
Mhatlen
I remember the coil spring bow even with drop down brackets that were on both my 2006 trucks when I bought them.
Which has to be winding back the caster since the axles noseing down forward to cause it.
The OUO are the best looking option out of all the links radius arm choices period. I paid almost $1,000 for my Fabtech arms and those were the second set I bought. I could have had OUO but I was in a spin I suppose.
I must have been drinking too much Jim Beam. Or maybe my head took a bigger hit then I thought totaling out my old F250 ??
But yea Regret doesn’t get close. I’m happy for you those things are the ticket.
Swampfox
TN
One Up Offroad
Adjustable link arms - SOLD
Carli Suspension
4.5” Coil Springs - SOLD
Track bar - $275
Sway bar and bump stop drops - SOLD
4.5” Fox 2.0 shocks - SOLD
List updated on what is still available.
