Carrillo / R&R Connecting Rods
timj
Wisconsin
I put Carrillos on my 6.4 this past winter. When test fitting, there are some cast nubs (4 total if I remember right on the outer walls (skirt) of the block. Only 1 nub actually made contact with a rod, but the others were close so I shaved them all down. The cap end of the rod made contact where the bolt head was just as a reference. Take in account the rough casting can be slightly different from block to block.
co04cobra
WV
for what its worth....we have a set of Carrillos on the way here for a 6.0 and a 6.4. be happy to share what we find out when we go to install them. R&R in the red truck were pretty simple, with some machining on the rods (very minimal) from what carrilo said, these should drop right in, may only need to machine some material off the bottom of the cylinder skirt if there is extra material. Of course that's engineers talking in the perfect bubble they like to pretend exists. Photos will follow
I would really like to hear back once you get the. 6.4 rods in what has to be clearanced.
Has anyone broke a Carrillo? What power and what was the setup ?
powerstrokedkid87
New Jersey
Although Carrillo only mentioned this was a question on some 7.3 blocks this is what I'm expecting to encounter.
Certainly will.
Breaking Habits
Mapleton, Illinois
The cylinder walls have to be clearanced. Not always necessary, but you should always clearance an motor even with drop in components. We did it on mine when we built the motor, its a piece of cake
I dont know of anyone that has EVER broken a carrillo powerstroke connecting rod
co04cobra
WV
That might be a better ? Has it been more common to see one or the other bend?
97stoker350
south central pa
pretty sure mike bent one while they were testing godzilla for dpc. i can't think elite would've put that truck together with stock rods
powerstroked08
Pennsylvania
I was positive they were stockers. Jared, wasn't the only guy to bend a carrillo Dallas penn with his duramax? Wasn't it a hung injector like a 400%or something retarded and hydrolocked the cylinder?
Rubenk
KCMO
Dang, didnt realize the aftermarket rods were holding up THAT well. Whats the weak link then? Block, crank? Head gaskets?
