Changed fuel filters now truck wont run?
powersmokin64
Johnson City, Tennessee
Ok so I swapped out my fuel filters and bled the lines pretty well. When i go to start it, the truck will fire run for a second or two then die like its not getting fuel. And I put the exact same filter that came out of it.
STROKER
id pull your filter cap on top and see if theirs fuel in the bowl
Dustball8504
Everett, PA
You have to prime it. Keep cycling the key while someone holds a screw driver in that valve right beside the fuel filter cap under the hood. I've also heard people say just cycle the key about 10 times and it'll build prime back up.
tbsimmons
Bakersfield, CA
I just cycle the key a bunch. Turn the key on till you hear the pump turnoff. Then repeat. When you think it is enough, do it a few more times.
BFT
southern cali
:whs:
the pump has to cycle when you bleed the air out then cycle it a few times after
tbsimmons
Bakersfield, CA
What I have used that helps with the smell and also gets pipe dope out from the drilling rig, Simple Green. I am sold on this stuff now for almost all cleaning.
Just spray on the areas that are bad and let it sit then throw it in the washer.
Has worked for me.
