charging issue
junglejoe
Mo
My truck starts out are 13.5---13-8volts in the morning. As I drive it. The Volta continuously drop to about 12.5 and sometimes to 11.99 at idle. Does make much difference if the ac is on or not.
My brother truck does the exact same thing .BRAND NEW MOTORCRAFT BATTERIES AND ALTERNATOR.. Didn't t change anything..
Anyone else heaver dealt with this same thing? I checked all the grounds ect. . I don't see anything wrong anywhere visually
79jasper
skiatook, Oklahoma
Does the battery light come on?
I would check the connector. May need a new pigtail.
Check out the charge wire as well. Could even do the wiring upgrade.
Sent from my SM-G892A using Tapatalk
junglejoe
Mo
No battery light..
What connector are you referring to?
Wiring upgrade.. You mean the battery cables?
03_PSD
Salado, TX
I will add this too. When I upgraded all the wiring, I noticed the truck spin the starter a lot faster.
junglejoe
Mo
Thanks for the link. I would think if changing cables.. Change all of them?
03_PSD
Salado, TX
You leave the factory cables in place.
Have you had a chance to clean and inspect the alternator connection?
