Chatter Noise
WoodBoy
Alabama
I noticed yesterday a chatter noise that seems to be coming from under the hood around the driver's side. I can hear the noise when slightly accelerating. It makes the noise from about 1400rpm till about 1900rpm and i cant hear it anymore since the injector rattle drowns it out above that. It sounds similar to valves rattling when you lug an old 4 banger or etc. I can't really pin point the noise under the hood. Any suggestions?
78f100
Bonifay FL
It's most likely worn rocker arms. Usually you can hear it under light throttle but goes away on heavy throttle.
