Recently I have been experiencing some shifting irregularity's and some idle stability issues when shifting between reverse neutral and drive, as well as a randomly flashing O/D light. I was able to retrieve a P0720 (output speed sensor) from the PCM and with the truck in park the speed sensor would fluctuate wildly (viewed from scanner).
First thing I did was measure the charging system for A/C voltage using my DMM and there was around .3vac.
Threw the scope on it to get a visual....
Anything above .2 volts A/C should be considered a problem. So I installed a new rectifier and everything is good to go. Keep this in mind next time your truck is acting up.
