CK4 spec oils.
Justin@DP-Tuner
Interesting stuff. It is crazy to watch the ever evolving world of motor oil. Lets just hope oil that works well for HEUI stays around. These engines are a little more oil picky than others.
dsberman94
Pennsylvania
I'll hopefully be calling you later this week for a pail of 8700. Going to run that for 5k and then probably switch to LE 5-40. Just want to get all the junk cleaned out on the 15-40 before going to the more expensive stuff.
no sense in going to 8854 in a 7.3 if you are going with 8700... maybe a couple oci in winter but that's it.. 15w40 will hold icp better.
dsberman94
Pennsylvania
I plan on doing one around 5k. Driving a lot of highway these days so they'll go on quick. However with that is going to come more idle time to warm up.
jimdawg185
Awesome, do you have my number?
616-460-9949
Countrycar
Texas
I switched to LE about 3 months ago. I went with the 5w-40. You say the 15w40 holds icp better? Maybe I'll go with the LE 15w40 next time see if it makes a difference.
its not gonna matter when just driving around but at wot longer in the oci..
jimdawg185
It will hold ICP better at wot. I usually recommend it first. If I didn't in your case I apologize. I'm usually pretty annoying about explaining all that stuff. But, you may give up cold start smoothness. Depending on your climate. So it's a balance.
jimdawg185
So the 15w40 has better cold idle characteristics?
Billy T.
[email protected]
The other way around, in heui engines. The 5-40 cold starts better, but you give up ICP hot. 8800 15-40 is a good happy medium as its cold start characteristics are better than most 15-40s but hold ICP petter than any 5-40. All 5-40s are a little lower viscosity at operating temp than 15-40. It's just the nature of how they get those oils to do that spread. And all 15-40s are higher vis at lower temps.
Basically this is just important in heui, in non heui the difference is really only important in very cold temps like below-20 and in very high power applications.
yeah what he said^^^ I should have explained it that way. but I think Billy was just being a smartass.. lol
Countrycar
Texas
No worries Pal. I'm just trying different oil's at this time to see if I see any difference's. I have an oscillating idle at OPT, but cold it idles great. I'm sure it's due to some tuning issue's. I like synthetics as well, they seem to do the best in my trucks. I usually run 5w-40 from Schaeffers, but thought I'd give LE a try. Out here in CA I could run a 40w year round and not have any issues. I've actually thought about it, I just haven't tried it yet.
