cknox121's slow build
Cknox121
Augusta GA
Update.... Cleaned all the rockers, bridges, rocker mounts, fuel rails, injector harness, hpfp, and injector hold downs with diesel fuel. Wire brushed the exhaust manifold to remove some rust so I can put some high temp paint on them. Pressure washed upper and lower valve covers, fan shroud, left and right battery box. Cleaned oil pedestal, turbo pedestal, starter and ac compressor with brake parts cleaner. Everything was super oily from leaky glow plug harnesses. Whipped frame, fuel lines etc down as well. Hope to stay half way clean while I reassemble the motor.
Also ordered the rest of my gaskets from sunrise. Got final price on some more parts which should be ordered by the end of the week, and I'm still up in the air about the body mounts.
Can wait to get the motor back, it should move along quite nicely then!
Cknox121
Augusta GA
Good stuff. Are you going to assemble the engine?
Machine shop is doing bottom end and installing the heads. I will be doing everything else.
How hard is it to get to the middle cab cage nuts? Back seat has to come out? Can't get my welder in good enough to get it from the bottom.
Cknox121
Augusta GA
Body mounts ordered... I went with the regular poly ones.
Does anybody know if you have to save the metal parts on the OEM mounts to use with the new ones?
Cknox121
Augusta GA
Thinking about throwing some 15% nozzles on while the injectors are getting flow tested... Thoughts? IIRC you can run a lower pulse width tune and they will do fine. I'm all for more low end power then top end.
Sent from my cracked iPhone using Tapatalk
B585Ford
WV
Definitely do the nozzles!!!!
B585Ford
WV
You maintain rail pressure with the lower pulse width tune?
Yeah, I need to get with GH to so that I can get the most of out it. My 2.3 PW tune only maintains 21500 but 1.9 PW maintains full RP. I don't have any of his tunes in between those PW. I am thinking about a 2.1 PW would be the max that I could maintain.
Cknox121
Augusta GA
Body mount bushings are in.
Cknox121
Augusta GA
I guess you have to reuse the metal pieces from the original insulators?
That's correct. Separating the metal pieces is pretty simple. I use a mixture of ATF and rubbing alcohol and poured down around the sleeve. Let it soak about 20 minutes and hit them with a hammer. Popped right out.
webb06
Seneca, MO
Ya I've replaced quite a few with oem. I was just curious since I didn't see any metal in the picture
Cknox121
Augusta GA
Okay so I did a little recon on the body mounts. Factory mounts, the tops are 2 and 1/8" thick. Day stars are a like 1 and1/2" thick. Do the factory ones compress that much?
