cknox121's slow build
08strokin
Maryville TN
Went and talked to the machine shop. Crank has a gash in it not sure what from. Rods are bent just a hair, and the portion where it connects to the crank is to far gone. Hopes to have it ready in 2 weeks max
Sent from my cracked iPhone using Tapatalk
A gash where? On one of the journals?
Cknox121
Augusta GA
That and a lobe. He couldn't explain it, said it could possibly have been dirt? I meant to snap a picture. And it was bent. Couldn't see it by eye but the machine don't lie.
all my rockers were together, and nothing was broken or shattered.
Cknox121
Augusta GA
So the crank has a gash/ score mark on one of the journals, and it is bent? Thats f**king weird.
What I thought. After I get it back I'm going to take it to another machine shop and see what they say. Same with the rods...
it doesnt surprise me the rods are bent honestly. the crank however; i would definitely get a second opinion.
powerstroked08
Pennsylvania
^^ Just what I was thinking. I can understand the rods, I get that but a bent crank? Sh!t how many 900+ horse builds don't have bent cranks! I understand balancing has to help with that but I doubt he was spinning 5K rpms on stock balancing.
Cknox121
Augusta GA
It has me second guessing my self if I should do some rods or not.
If they bent on a stock tuned truck, then how are they going to like a 71/59 combo?
powerstroked08
Pennsylvania
If I ever have mine apart I will do rods. Just the piece of mind is worth it really. Once you do rods and pistons your really set if you ever want to add more power.
Cknox121
Augusta GA
Yeah I hear ya! I'm on a small budget but one day I will be able to do it!:D
I have no budget lol. I'm scarred to see what the machine shop bill is going to be. Just x amount in the bank that I have had saved up for this. Kinda eating my own words but I told the machine shop I want it done right the first time. If you even think it's worn replace it....guess I should by rods then lol
tuning plays a major factor. i would not worry about the rods with the 71/59 as your back pressure could potentially be a little lower. i personally wouldnt run anything but gearhead tunes.
low rpm fueling does not help rods survive neither does extreme back pressure
Stroked777
Casper, Wyoming
I did my grill the same way, peeled off all the chrome. What a pita but was worth it I. The end. Nice thing about a black truck is that about any black works, I rattle canned mine, from far you can't tell but up close there is a little texture difference, that's about it
Cknox121
Augusta GA
Good to know! I thought torque bent the rods?
Planning on a wastegate down the road.
Thanks. I took it completely apart. Whites a little harder to match imo
Stroked777
Casper, Wyoming
What kills rods is low end torque. You got all that torque and no Rpms. When you have a tune that will dump as much fuel as possible at any boost range that will create a lot of cylinder pressure and that bends rods
Cknox121
Augusta GA
Picked all this sh!t up at Rudy's today
Now I just need a damn motor...
