webb06
If you can afford it, it's the only way to go. Morgan will take real good care of you!
I've got all the stuff you should need. Be glad to discuss options.
There is still a good amount of the a-1's left if you want them. Although I don't know how much longer they will last. But they will no-longer be making anymore. At least until someone buys them out and starts producing them again.
On a side note I have no complaints using arp's and the price is cheaper.
Check out the website www.midwestdieselauto.com
What makes them better then ARP? What's the torque required on them?
Do they make the custom age 625 for the 6.4?
Not to derail but why arent they making arps anymore???
Arp 2000's and a-1 1722's are the same tensile strength.
H-11 and custom age 625 are the higher tensile.
I don't believe they do, anyone correct me if I am incorrect.
Pistons, if you dot want them to crack and ruin a cylinder wall the de-lipping is a must. Coating also helps with heat and cracking issue. The valve reliefs help you from having piston to valve contact should you have a problem like valve float.
Aside from that there is no performance gains, all for reliability and keeping it from having bottom end issues.
