Cleaning head gaskets
907DAVE
AK
From the manual:
NOTE: The cylinder head cleaning and the cylinder head distortion check procedures are different than other engines. Watching the video prior to carrying out the procedure may be helpful if doing the procedure for the first time.
NOTICE: Do not clean the cylinder heads with steel scrapers or blades, which can cause scratches or gouges that result in leak paths. Also, do not use rotary abrasive tools including: pads, disc, wire brushes, sand paper or emery cloth. These products can alter the surface finish of the head, adversely affecting the combustion chamber sealing.
NOTICE: Cleaning the cylinder head employing any other method may cause a non-warrantable condition.
NOTE: Use a brass scraper such as the Grainger 5LL98 brass scraper and a non-abrasive Scotch-Brite(TM) General Purpose Scouring Pad 96, or equivalent to clean the cylinder head.
With the valves installed, clean all the cylinder head gasket surfaces with metal brake parts cleaner and a brass scraper to remove the hardened carbon deposits. Repeat the process as necessary to remove the hardened carbon deposits. Then, use the general purpose scouring pad to remove the remaining residual deposits.
Use only a lint-free rag to wipe the head gasket surface after cleaning.
NOTE: Staining of the metal surface is normal and does not affect sealing ability.
NOTE: Witness marks or indentations in the cylinder head resulting from the head gasket fire rings are normal and do not affect sealing ability.
Clean all bolt holes and be sure that the gasket surfaces, oil return holes and coolant passages are clean. After rinsing thoroughly in hot water, blow the passages out using filtered compressed air.
MarkSmith
These are what I refer to. Sorry for the delay.
Leaves a nice smooth finish. Never had a problem with gaskets sealing.
Sent from my SGH-T989 using Tapatalk 2
Alfie
Horrible state of CA
^^^ still not recommended by ford. But on the flip side come co-workers clean them using this with no issues but I haven't. I stick to my good oh brass scraper
01PSD
Smithfield, NC
I dont see a problem with using them as long as you dont go crazy. Just knock the bulk of it off with the disks.
Twan
Berthoud, Co
Thanks. The tech told me how he cleaned them, and told me some of the stuff he has seem come in. So I just wanted to see how others did it.
co04cobra
WV
You can't beat the way these clean without taking off material.
01PSD
Smithfield, NC
What about the block surface? I know damn well the Ford tech's used a roloc disk on my block surface at least one time.
I see no problem with using a roloc disk to just knock off the bigger stuff. Just don't sit there and grind away with them LOL That's what we did followed by the honing stones.
ford_trck
Vail, AZ
A 2x4 with finer grit sandpaper and some oil. Once you have the large stuff off then use it to go in an x pattern across the block surface.
