long story short, if you loose your input shaft seal and get a bunch of ATF in your clutch, your going to need a new one!
I've been corresponding back and forth with Ryan at South Bend and his recommendation based on how I use my truck is that I go with a clutch vastly similar to the street dual disc (SFDD3250-6), but WITHOUT the damper buttons on the center plate.
I have no experience with an undamped dual disc clutch, how disruptive is the noise?
