code help
04redcrew
mt vernon indiana
hey guys
had a code pop up on me twice now in about 2 weeks. Just curious to what it is and what do i need to do? Is it anything to worry about? Code is p007E says Charge air cooler CAC Temperature sensor intermittent/erratic bank 1. Thanks for any help
Mesa, AZ
Ive seen several of the pigtails on the sensor in the black tube get chafed, eaten by rodents, or other damage. Also seen a handful of sensors die.
Mesa, AZ
Its in the plastic cac tube. Down just above the bend where it comes off the cac. It faces the engine, and the pigtail has a christmas tree holding it to the tube, just to the drivers side of the tube. You can usually pull the tube up high enough to undo the christmas tree and access the sensor and pigtail. The clamp at the cac is 11mm nut, and it usues a spring type clip you need to dislodge out of the groove to remove the tube from the throttle body.
