Code p1910, stumped
Harley Strokin'
Northern Va.
Ok so truck started acting weird a few months ago, the reverse light relay started clicking driving down the road making the reverse lights come on and off. Replaced relay and no change. Pulled a p1910 off of my insight saying reverse lamp circuit low. Had a friend hook Ae up to it and pulled an couple codes for the x-fer case, can't remember the specific codes. The 4x4 has failed to work a couple times but usually works great. Any thoughts or other tests I can do, pretty decent w/ a multimeter.
caggr5
Calgary, Alberta, Canada
Did you ever get this one solved? I have a 2008 F350 and while I don't have the relay clicking and lights coming on/off what I do have is no back up lights or park sensors. When I pull the codes I get P1910 ( reverse lamp control circuit open) and also two codes under what they call the 4x4 control module , p1876 and P1832 which relate to the transfer case and transmission transfer case respectively.
Since thus sounds almost the same as you issue I am curious what your solution was?
Any help is appreciated.
