Codes after installing injectors low voltage?
jrex2506
I just installed 155/30 injectors, running rough after 10 minutes of idling. Codes are p0264( #2 low voltage) p0273(#5 low voltage) and p0277(#6 high voltage)
Should i assume the injectors or harness? Checked ficm, its at 49 volts. Will use scan tool tomorrow to check each injector. Just getting an idea, or did i not run it enough to tell, only idled for ten minutes, no driving or anything.
