DocBar
Last Friday, I did a hard WOT run on my truck and pulled the following codes:
P0344-camshaft position sensor circuit intermittent
P0541- Manifold Intake Air Heater (non-issue)
P0571-Brake Svdtch A Circuit Malfunction
P0603-Internal Control Module Keep Alive Memory (KAM) Error
P0605-Internal Control Module Read Only Memory (ROM) Error
P0703-Brake Switch B Circuit Malfunction
P1142-Fuel flow restriction??
P1209-Injection Control System Pressure Peak Fault
P1282- Excessive ICP
P1744-Torque Converter Clutch System Performance
P1780-TCS Circuit Out of self Test Range
I got this one the next day
P0470-Exhaust Pressure Sensor Malfunction
I get a P0232 code several times a week.
I just had a BTS 4R100 put in and have about 1,000 miles on it.
Today, the truck started getting hard to start. Slow cranking and shuddering before it would start. It hunts for its idle a bit then settles down and runs fine. I'm thinking CPS on this. I have a crappy grey one in the glovebox and will be finding me a black one ASAP.
Any ideas? Should I hit the panick button?
I'll be pulling a 12K# 5th wheel to Georgia in the next few days. I hope.
