Power Strokes
6.7 Tech
codes p0100
[QUOTE="97cherokee, post: 1543925, member: 22488"] hey all I have a 2014 6.7 that is fully ******d and has been for some time. today I got code p0100 for the mass air flow sensor and another code for glue plug controller communications. i did some quick searching and found that often fuse 36 is blown due too shorts in the box sensor or its wiring. i checked fuse 36 and it's not blown, the box sensors are off of mine since its ******d, looked at the wiring and found that yes it is corroded so I unplugged the 3rd connector on the pcm and cleared the codes and rechecked and it still has both codes. I figure if the problem was down stream unplugging the emissions harness it would of eliminated the corrosion as being the issue or am i wrong? where would yall suggest I start? [/QUOTE]
Latest: gahm3r
Yesterday at 4:16 PM
6.4 Tech
Latest: 03f3507.3
Yesterday at 2:11 PM
Engine and Drivetrain
Latest: ToMang07
Yesterday at 7:28 AM
B
No Start help
Latest: bismic
Yesterday at 7:04 AM
Latest: 6.0 Tech
Wednesday at 8:24 AM
Ford Power Stroke News
ncollins64
tangoparson
cjbouressa
Power Strokes
6.7 Tech
codes p0100
