JoeDaddy
I have the option for either, which is better?
Ecswb solid axle 6000#
Leaf springs are real simple to and hard to mess up. Still ride good with a good set of shocks. It is very simple to just twist some adjustment screws on a set of shocks to change overall driving characteristics.
Coil springs you have to either change out your old axle for a newer one or make some mounts on the axle and some buckets for the springs, probably a newer steering box. Then you have to fabricate your setup whatever you are going to run, 4-link 3-link. If it is a dedicated dragster than you don't really have to worry about how the the truck behaves out in the real world. If you do than it will be alot more challenging than a leaf spring setup and far more expensive.
It is real hard to mess up a leaf spring setup, just my opinion.
Now I'm just looking for a reason why it might be a bad Idea.
What about handling at the big end. I'm aiming for 120+ trap speeds. When the nose goes down how badly will the truck react to the track bar shift? I'm planning on lengthening the bar for less shift but "gas on" to " brake on" is a bad time to get a sideways hift at 120 mph.... No?
Have any of you noticed this on your trucks?
I havent dealt with the coils on the competition side of things, but it seems like they have a harder time controlling hop when pullin.
Anybody else noticed this?
Joe - the track of the vehicle won't change under the small amount of movement you suggest if you maintain good geometry on your track bar and your drag link. A good rule of them is to make them both the same length and parallel to each other - then they will follow the same basic path throughout the motion of the front end and keep you going in the same direction as you intended no matter how much or how little your front end suspension is compressed.
