Since it has been getting cold out my truck has been struggling. When you glow plug it the engine will fire right up and run great. the engine will continue to run good till about 30 seconds after the glow plugs turn off. A little after the glow plugs turn off you can feel the engine is running rough and missing and if you let it idle it will go all the way down to about 450 rpm. When it will idle way down it almost sounds like it is running out of fuel but the pressure is steady at 65 psi. I also noticed that the icp duty cycle is 21-22% and the icp pressure is around 1200 psi. Once the oil reaches about 105-110 degrees it will start running great with no problems. Has anyone ever had problems similar to mine?
Chris
Chris
