my current mods are a Dptuner, custom built Ponci's Diesel Center Transmission with Suncoast torque converter, Gillette Diesel Compressor upgrade, HPX, riff-raff FPRX, AFE stage 2, 4" exhaust, Zex nitrous kit, AEM Water Meth. I plan on running 238cc/100 injectors with Walbro lift pump. I also plan on doing ported/polish the heads, comp cam 910 springs and shims, and pushrods. What do you think would be a good streetable compound setup? If not a stock turbo maybe a 62mm turbo with a 71mm turbo arrangement? I want a turbo setup that will spool up incredibley fast, decent top end, with really low egts. As much as I enjoy the black smoke I'm thinking I want to get rid of the smoke and have huge power all through the rpm band while being smokeless.
