Groomzybanshee
Thinking about building a set. Does any body have any photos of there setup I can get a look at?
Dave, would be interested to see what you come up with, it'll be bitchen I'm sure, since you've been running compounds for a while now.
I still dream of cleaning out the valley and figureing a way to drop a set of street compounds in there but that would be like trying to figure a way to use your cruise control buttons to manually shift a 4r100.
Oh wait, what?LOL
search for me on either facebook or photobucket, i think there's pictures on one of the two or both. Mine was mounted above passenger side tire, no windshield washer fluid, vac resevour and no inner fender. I will never run twins on a street driven 7.3 again, what a pita. Any routine maintenance was just that much more difficult and time consuming. Yes it was more fun to drive than the big single, but the extra work just wasnt worth it.
You usually voice this sentiment in this type of thread, but I have to alert you to the fact that you don't have to mount the first stage where it totally ***s all that up, lol.
You didn't have to lose the windshild washer tank, vac reservoir or inner fender, point blank. Nothing about compounds says you do. You could mount a single turbo like a total retard and have to remove all that stuff if you wanted to be dense and place it there, lol.
I know you didn't choose the location or anything, I'm just saying, your points only apply to that ***ed up setup. Not to "compounds" in general terms. I would qualify your statements with something along the lines of.... "on my sh*t ass set of compounds", lol.
Something to think about...
My original setup takes the place of the AC and vaccum reservoir because those things were long gone years before I fabbed the charger setup. I didn't remove them to gain room. If I had wanted them I would have positioned the charger slightly differently, as many have since...
Only point of this post is to clarify that the negatives listed above are not inherent. You have to purposefully place the charger in the way of all that. Compounding in itself does not mean you have to lose those things.
Just as there are other angles than parallel to the crankshaft.to.mount the first stage. Why do compounds thrash stock FR bottom ends? If you tuned a set of compounds on 450hp worth of fuel.would it decimate the bottom end like we usually see?
My guess would be that the torque comes in so quick in the rpm range, also i dont think that a set of studs would hold the heads on even if held to 50-55psi of boost it would be the amount of air be forced into the combustion camber.
40psi at 900cfm say 38r
40 psi at 1250cfm KASB
40 psi at 1700+cfm compounds
