bootcamp
Got my Blackstone report back and it said positive for antifreeze in the oil. Yes I have used the archoil additives and my understanding is this can give a false reading. So with only 1500 miles on the current oil change I came home and did a complete oil change including a new bypass filter. Took another sample and waiting on the results now. I also change my coolant filter and there is a ever so slight residue of oil across the top of the coolant that was drained from the old filter.
Just did a complete head job late in 15, and put a new cooler in early 15. We went with aged arp studs with oem gaskets and ucf oringed heads. What are the chances this is a cracked block/cracked heads or an oil cooler?
If I have to bite the bullet and do an oil cooler, I'm replacing it with one of BPD units and not have to worry about it again.
Need some guidance here, do I need to look for another motor or oil cooler?
Thanks
Thanks
