Coolant leak? Can't find it.
Powerstroked6.7
Washinton
Well you know that Ford has those awesome plastic tanks that always seem to leak, i just replaced mine at 58,000 with a sweet unit from Mishimoto
TrickTruck
Simpsonville, SC
If you dl3ted ERG w/ H&S look up there where the rubber cap is. Lay on the ground, passenger side radiator end cap, about a foot up from the frame.
These caps are prone to cracking.
I know I was all ready to replace the radiator when I finally figured it out. $2 part at autozone was a lot easier.
Worth a look anyway.
ShotgunDave
South Carolina
Mine started leaking at the same spot about a week ago. Its at the dealership right now getting a new radiator installed. From what I've read its a fairly common issue.
O4ep3civ
Still don't understand how inconsistent the leak is. When it's parked outside at work it will leak. In the garage it won't. I don't get it. I'm going to go through everything tomorrow.
