couple ???s
97stoker350
south central pa
im looking at the gqssb full setup and i was wondering can you install all of the stuff without pulling the motor? also when it says 4 inch turbo back exhaust does it have a 4 inch down pipe? will it fit on an obs 7.3
97stoker350
south central pa
well what size does a 4 inch turbo back exhaust come with. also what will perform better a gqssb or gt 40 with a manual, used as dd and occasional light towing and pulling with stage 2 injectors and stock fuel and oil
smokedout250
harrisburg oregon
Ever looked into an irate setup? I run the irate s366 on my truck! I have a manual as well! Not trying to say the other is bad.... They ate an awesome setup…
97stoker350
south central pa
well i plan on making 600 hp or better some day so i want a turbo that will run good for now like 450 hp but i wont have to change down the road
smokedout250
harrisburg oregon
So then why are you going with stage 2's? Why not go bigger injectors.... Just have them detuned... Also for 600hp you would have better options with a different mount just my 0.02
smokedout250
harrisburg oregon
It's all done with custom tunes on your chip! Idk who you run for a tuner but tell them what you are gonna have for supporting mods so they can tune according to it... I believe cat rebel on here has 250/200s and he's running a stock turbo! Plus your not gonna make 600hp on 238s
davey99ps
Waterford WI
First you need to pick a hp goal an what exactly you wanna use the truck for, it may sound dumb but really think about it. Once you get your goals decided, then we can get you pointed in the right direction.
neverkickn
AR
Pulling trailers around on the highway and around town, or pulling sleds down a dirt track?
