crank case venting idea
Jbird
if you guys run a catch can make dam sure its restriction free. either back to the intake or to the exhaust.. if not, you will build pressure and start pushing oil from places you dont want it to..
How do i check if its restriction free.
Honestly i just wana run my exit side all the way to the back of the truck with the little cheap filter
if it's not routed back to the intake or exhaust to help pull/scavenge out the gasses and it has any sort of catch can/filter on it then it will have some restriction on it.
personally, I would run the ccv hose to the front bottom side of the motor so the fan can mix fresher air with it to cut the stink.. might have some drips on the front axle but think of it as undercoating. lol
johnp115
Southern MD/Charlotte NC
Exactly lol, again.. why i say just route it to somewhere less obvious. Its not that bad, if the smoke is super obnoxious then maybe you have bigger problems.........
Jbird
So even if i ran the tube from the ccv all the way near the rear tire and just dumped exit it would still be restrictive?
as long as there are no low spots then you should be ok.. i tried that with my dually and it started pushing oil out of the 38r.. but those are more sensitive to cc pressure..
Jbird
I might just try running out to the back. If not ill do the the angled cut into the exhaust.
Jbird
What do you mean by low spots
snik
Mine doesn't have a straight route after the catch can. But I see it puffing smoke out daily.
Once it leaves the catch can which is essentially under the cab right under the pedals. It leaves there and goes up over the frame then down and opens up just aft the front axle.
Jbird
Im just tired of smelling it instead of smell diesel
so theres a high spot in it over the frame? or is it level over the frame?
snik
[emoji32]... im surprised you dont have oil leaking out somewhere other then the ccv..
Only oil leak I have I think is the rear main seal or the oil pan gasket. Haven't determined which one it is yet. But I don't think the ccv bypass has anything to do with it.
I don't see how it makes such huge a deal as u make it sound tho. It's just smoke. All that crap goes up out of the valve cover before it drops down to the catch can. I'm sure a slight rise of maybe 6" from the catch can isn't affecting it enough to cause a leak anywhere.
its oil vapor, as it cools, it turns back into oil and will build up and be a thick sludge and wont flow uphill... how long has it been routed like that?
Jbird
Well my catch can is mounted to the front bumper under the passenger headlight. The exit port runs up directly behind the headlight where it has that cheap filter to cap off the hose. Idk whyyyy they did it that way i told them i wanted it under frame towards the back. Idk like i said i can barely smell diesel over ccv smell and im sick of it. I like that smell of diesel[emoji58]
Justin.D
Jamul, CA
Its not too complicated. Just run some 1" heater hose down to the frame, into a catch can made out of 2" PCV pipe with a screw on bottom. Use rolled up scotchbrite to filter out the oil. Then run heater hose back to the intake. This set up has been on my truck for 25k miles now, and filters out probably 4 oz of oil every oil change, zero smell, zero oil on the ground or in the intake, and zero leaks from crankcase pressure.
snik
Well to the catch can it runs down. Any oil that makes it past the catch can should flow back down to the can.
It's been this way for some time now.
