Crank no start (sometimes)
powerjoke4life
96 7.3 stock motor
The truck will crank but not start, no WTS light (this hasn't come on for a while) no tach movement while cranking, after trying a few times if I go back out there an hour later it'll fire right up. Drive around fine, but may die.
Checked all my fuses for the PCM they all look good.
I think it's the CPS but is there anything else I should check before going to buy a new CPS?
Turbtators
Illinois
Cps isn't to expensive and its an easy install. Worse case scenario its not the cps then you'll have a spare cps when it does go out. Do you have any check engine lights? Also do you have anyway to check hpop pressure?
powerjoke4life
Ya thats about what I was thinking, I just know by the time I get the part, get home and put it in Ford will be closed and if I need another part it will have to wait another day. Just wanted to see if there was anything else I could look at before the dealer closed today.
I can check the oil P but it will have to wait till tonight. Would the HPOP go in and out like that? I figured it would either work or not work. If it is sitting why would it start one time but not the next time?
Turbtators
Illinois
If you have no tach movement I would think it'd be cps. Only way I would think the hpop would go in and out is if you had a short or bad sensor.
powerjoke4life
Ok cool, I will get the CPS ordered and try that out. Is there a way to test the CPS?
Im at work so hopefully it starts right up after work and I can get it home to check the HPOP
Turbtators
Illinois
Im sure you can check it. I do not know what resistance or voltage would be acceptable hopefully someone can give you that info.
jschildm
Southeast Iowa
Could a no WTS light be IDM fuse? I can't remember what fuse number it is. Perhaps just a short or something in its wiring.
Arisley
Arlington, Texas
Just swap the PCM relay with the blower motor relay.
They are the same in a superduty, I am assuming they are in the OBS.
mandkole
Northwest
I used to get a random no start with the OBS. You could start it fine for 50 starts, then on 51 and no matter the situation, it would just crank. You'd stop cranking and rekey it, it would fire right up.
powerjoke4life
Been running around crazy the last two days. Part will go on tonight and I will let you know how it goes.
