nvme_63
Had a customer vehicle come in, crank no start with p0003, and p0091 codes, with IDS on it rail pressure on cranking was 25psi with 5k desired psi.
Replaced the pump and harness (used pump from a member on here, per customer request).
Still crank no start, now IDS is showing 220 psi while cranking, I have bleed high and low pressure sides.
Still get the codes, did I get sold a bad pump or do I have another issue I'm over looking?
