Crank slowly died to no crank no start
Decker
Michigan
As title states 06 F350 started fine this morning. Went to leave work and crank slowly to no cranking at all. No ticking nothing. I tested both batteries and both good, only two months at that. When I turn the key lights do not dim. I believe it is the starter but don't want to just toss money at it. Only thing I have tried so far is to try and started off of ignition wire in fender well and nothing happen. Any other ideas?
Mesa, AZ
Hes telling you to loosen the belt and see if it cranks over good. Ive seen it quite a few times as well, either AC compressor or alternator locking up. Could very well be a failed starter too though.
