"Crude Intentions" Build
Shafer171
Michigan
Sucks about your truck man, who is doing the work this time?
Build sheet as of now
Elite Turbos
RCD 100's
Lee Machine k16
Elite fuel cooler
Precision intercooler
No Limit charge pipes
Alum Degas bottle
Branik Motorsports front axle shafts and drive flanges
Detroit locker for the Dana 60
Nitrous kit of some sorts.
I'm doing most of it myself this time around, the new house has a nice shop that it fits in. Changing the setup a bit as well. Gonna have some help from a guy in Canada :thumbup:
bigrpowr
<How I Fly
Administrator
be careful, they are touchy feely LOL
gman1
Michigan
I thought about recommending that to him but Even Tadd admits those 72's never last and tend to let go real easy. Add nitrous into that mix and I don't see that going well and those 72s are not a readily available item from Tadd.
Ya Im sure Tadd would recommend and sell something that would not last. And anything Elite sells is not readily available.
strokeofgenius
Louisville, Ky
There is a machine shop in IN that supposedly has built a K16 that has maxed out Swamps flow bench. I am supposed to get one of their pumps to test and see if I want to take to DCP with me. If that falls through Ill run the Elite twin kit i have in my garage.
What's this shop that you speak of.. interested in that pump..pm me if you would rather do that. Thanks. Awesome build BTW!
08 F250 RCD 369sxe, 6.0 manifolds and rcd hd up pipes. arp studs. rcd pushrods and hd lifters. no limit intake. Patriot ost soft tunes.
Oil Field Trash
Jonesville MI.
PM sent
Sent from my SM-G955U using Tapatalk
Oil Field Trash
Jonesville MI.
How did you make out?
Not worth a damn. Signed up for 2.5 just to test the track, placed 22nd. Then I tried picking a better line in Workstock than they had been running all day. It back fired on me and I needed up 30' behind 1st place in 9th. But I had a blast!
Oil Field Trash
Jonesville MI.
Looks like it, maybe too much?
That's what I thought and 2nd guessed my normal tire pressure. Next year I will not add any pressure. I should have left it where it was and let it eat. I've yet to see run spin but that track would have done it!
